you should be ok with these value also tell us more about your set up just be sure your dizzy is set according to the ecu value , using timing lamp and ecu dizzy sync function
im running stock b16a engine with t3 turbo and wastegate runing .5 of a bar thing is can i run some more timing on the car and what sort of power would it be mybe 220bhp ?
on stock B16A2 it's possible to go up to 350hp on stock internal with bigger injector it depend of your turbo set up , injectors, fuel pump, exhaust size.... and the ability of the tuner also octane rating of the fuel you are using!
The value would be good i would change the map sensor so you could be able to tune for more boost pressure up to 1 bar and enjoy more power the ignition timing must be set on a dyno to be perfect, if you want the best of you set up
