				what sort of timing can i give pics inside
				Posted: Sun Jun 30, 2013 6:52 am
				by eric o neill
				ok ive a b16 engine turboed wat sort of timing is safe for my engine as how much can i add,im running .5 bar boost on a t3 turbo
				Posted: Sun Jun 30, 2013 7:05 am
				by David974
				you should be ok with these value   also tell us more about your set up   just be sure your dizzy is set according to the ecu value , using timing lamp and ecu dizzy sync function
				Posted: Sun Jun 30, 2013 9:54 am
				by eric o neill
				im running stock b16a engine with t3 turbo and wastegate runing .5 of a bar thing is can i run some more timing on the car and what sort of power would it be mybe 220bhp ?
				Posted: Sun Jun 30, 2013 10:40 am
				by David974
				on stock B16A2 it's possible to go up to 350hp on stock internal with bigger injector   it depend of your turbo set up , injectors, fuel pump, exhaust size.... and the ability of the tuner   also octane rating of the fuel you are using!
				Posted: Sun Jun 30, 2013 11:52 am
				by eric o neill
				useing 95octane also upgraded pump and 560 injectors
				Posted: Sun Jun 30, 2013 1:29 pm
				by David974
				The value would be good   i would change the map sensor so you could be able to tune for more boost pressure up to 1 bar and enjoy more power   the ignition timing must be set on a dyno to be perfect, if you want the best of you set up
