Different ecu - different behavior
- civic4g
Hi I've been using an p30-g01 on my ek4 but a few days ago i've changed it with an p30-g00 and have nottest that when i swith on the ignition (position II i think) the CEL doesn't come ON as quickly as when i was using the p30-g00. With the p30-g01 the CEL was instantly ON as the other lights (oil pressure, Brakes...) Have you guys ever seen this kind of issue? I just want to be sure that it's nothing wrong with this ecu.
Best Regards Filipe Costa
- Bindegal
I never really noticed any delay in the check engine light. However, in other ways the ECU´s ARE in fact slightly different. Little differences in A/D converters and other components is something you need to be aware of, for example when using 3 bar MAP sensors and large injectors. Mostly this affects just idle, but I have even seen WOT affected. For that reason I ALWAYS confirm and, if necessary, fine tune on the actual ECU that will be driving the car. /Allan
scttydb411
i always recommend tuning on the ecu that will be used in the car. if a replacement has to be used in the future then double check for any fine tuning. even though the components/boards may be the same on 2 ecu doesn't mean the component run is the same and slight differences may be exhibited. i notice this more with idle between p28/p06 vs. p72/p30. i've seen first hand tuners that spend a whole session tuning on their \"tuning\" ecu to only learn this when they burn the chip and swap the owner's ecu back into the car. why waste the extra time?
- Bindegal
With bigger injectors and MAP sensors, I ALWAYS see a difference. Sometimes not a lot, but I usually have to fine tune at least injector offset. That usually does the trick. I use my own ECU for the majority of the tuning process because I grew tired of all those annoying wires. So my tuning ECU has a built in wideband controller, and Ostrich + USB hub strapped on top. This setup has proven to be very reliable and saves me tons of time. /Allan
Thanks guys for the replies. That issue happened with the same chip/rom in 2 different ecu's (p30-g00 and p30-g01). So far the only difference i've nottest is the CEL \"behaviour\" as it takes a little bit longer to turn on. I've talked with a friend that is also using an p30-g00 and he also has that delay with the CEL turning ON, so that must be normal i hope
So no afr changes, thats the important thing. CEL delay i have experienced with a 900 and 901 P30 also when using the SSt512 chip, didn't do it with romulator. Fast CELSo far the only difference i've nottest is the CEL \"behaviour\" as it takes a little bit longer to turn on. I've talked with a friend that is also using an p30-g00 and he also has that delay with the CEL turning ON, so that must be normal i hope
I have heard of using the ostrich/vs chips sometimes required a last adjustment if an AFR reading was done after the chip install... this was with CROME. for another note: taking the internal CPU program out, and putting it in my ostrich made me leaner. I have no clue why. This was with a P08 ECU.
