This is a brilliant way to drive low AF's with a narrow band. Let it drive closed loop and remember what the injection time is at closed loop to run 14.7. When it is possible to drive lean, disable closed loop and lower this injection time by X%. When the driver is changing the revs a bit, just go back to normal closed loop and do it again. This can even be a possible eCtune feature!Once in a while the ECU injects one shot fuel to check if the CRANK and lambda are still working.. AF shoots a bit lower then. I don't think that the OBD1 version does this too?
