Tuning on Load Dyno- Dyno Dynamics
I was testing out a car on a load based dyno for the first time. It was a dyno dynamics. I have a question about loading it now. The dyno operator held it at 60mph which was roughly 4500 rpm's. Now can i use this load to tune all cells before 4500 rpms? The dyno operator told me in order to tune 4500rpm's I must hold it at full throttle. But the thing about that is I was just tuning part throttle. I don't get how the dyno works and how I can take full advantage of tuning on it. Thanks.
I like to start off by locking it at 20 mph, then put the car through various loads, Meaning ill hold the throttle at 10% and then tune tel cell that are affected. the go to 20% and so on. You do not want to put a huge load on the dyno for a long period of time because thats not easy on your car or the dyno equipment. I then increase speed and repeat the process over and over again. This lets you tune your car at various speeds at various loads so you can get to cells that are hard to hold steady on the street. Thats why they are better
ok let's say you lock it at 20mph and hold it at full throttle. i am thinking that in real life driving i would never go into those cells. correct? so basically maybe i should tune up to 40% throttle each time i load it? for example load at 20 mph, then 40 mph, then 60 mph? hold it from maybe 10% throttle and keep tuning until 40-50% throttle? maybe a little more throttle as the speed goes up? am i making any sense lol? i just got confused by the dyno operator. he really doesn't know anything about cars and he said if i'm not at full throttle during a load held pass, then there is no load being applied and i am just spinning in free air lol.Adam Hopkins wrote:I like to start off by locking it at 20 mph, then put the car through various loads, Meaning ill hold the throttle at 10% and then tune tel cell that are affected. the go to 20% and so on. You do not want to put a huge load on the dyno for a long period of time because thats not easy on your car or the dyno equipment. I then increase speed and repeat the process over and over again. This lets you tune your car at various speeds at various loads so you can get to cells that are hard to hold steady on the street. Thats why they are better
- Synoptic
talking of loading dyno. If you want to buy a dyno and can afford good money, have a lok to the Dynapack. that's what I have. it uses 4amps on 110v and is precise within 0.03% of error. meaning each pull will be measured the same. so if you see differences, thats means, there is a difference.
I have a Dyno Dynamics... Your operator can lock it in at different speeds. So for part throttle you are going to want to be in 2nd or 3rd gear and hold the load at 20 mph. Increase the throttle slightly while holding at 20 mph to access all of the load columns. Once they are good, increase to 24 mph...and repeat. Increase 4 mph increments until you are at the ceiling of your low cam maps. Make sure to keep an eye on coolant temps. A good fan in front of the car and keeping the heat on full blast in the car helps quite a bit.
- Synoptic
Yeah, and if it's a HB you tune, open up the HATCH, makes hot air escape, you will feel less dizzy on very hot days !xenocron wrote: A good fan in front of the car and keeping the heat on full blast in the car helps quite a bit.
