Fastest fwd lap record @ Dover Race Way, JAMAICA
- fah
On Sunday during qualifying for the MP2 (Modified Production Class) at Dover Race Way Jamaica. Peter Jaggan Drove his eCtuned all-motor 1991 (B18 219whp/149ft-lb) Honda CRX to set the record for the fastest fwd lap time of 1:26.932.
- peter jagan - 2.jpg (100.51 KiB) Viewed 14323 times
- peter jagan - 1.jpg (97.48 KiB) Viewed 14323 times
- peter jagan - 3.jpg (104.9 KiB) Viewed 14323 times
- fah
Come on guys ...lol - B18B (LS) crank shaft in a B18C block - B18C header port and polished - Cosworth piston 12.5:1 comp. - Skunk2 Stage3 tuner Series cams - Hytech Replica Header - OBX ITB's Tuned on 103 octanerelic1 wrote:Congrats!!no kidding, a B18 with 149ft-lb?Gaskleppie wrote:What are the rest of the engine specs?
- fah
The previous engine B20 vtec had made 240 whp/163lbft but the oil cooler had a leak, engine ran low on oil and got damaged. So the B18 was reinstalled as this was the bottom half that ge used to win his class championship last year. The B20 setup was very powerful... only wish he had more seat time with it.... i cant waite to see what lap times he will do when the B20 setup is ready again.
skunk2 stag3 tuner cams are too big for this kind of engine. Maybe 86x95, but anything less with will loose power and torque untill 8000rpm compared to skunk pro2 cams. i also have a dyno plot to proove it, the car is owercammed
- fah
well not in this case you are wrong not every setup is the same not sure what you did wrong maybe u need to degree and dial in the cams or maybe yur compression is too low ... we used 12.5:1 pistons but the head was skimmed bring the compression to about 13:1 or a little more The car made good torque and mid range power... not lacking anything anywhere and the linear power proved it at the track.EITCP wrote:skunk2 stag3 tuner cams are too big for this kind of engine. Maybe 86x95, but anything less with will loose power and torque untill 8000rpm compared to skunk pro2 cams. i also have a dyno plot to proove it, the car is owercammed
- g.t engineering
Fastest fwd lap record Dover Race Way JAMAICA
middle school i only know that our school has a mile record of 4:45 also county record and i dont know anything else. i did 56.4secs in the 400m last year but i dont know if that is a record or not because our school is like 60yrs old and they cant look it up
cr was 12.6:1, 85x89mm cams dialed on a dyno... whatever, if you think they make a good job, good for you.i know Larry Widmer the owner of Endyn told me few years ago skunk2 stage3 were first developed and used in accord racing team in h22 engines for circuit races with great success. Then skunk2 copied lobes and lift for b series engines but Larry told me every b series engine will be overcammed with those cams. i never knew untill i bought my own dyno and tested them myself...g.t engineering wrote:maybe your cr was too low.EITCP wrote:skunk2 stag3 tuner cams are too big for this kind of engine. Maybe 86x95, but anything less with will loose power and torque untill 8000rpm compared to skunk pro2 cams. i also have a dyno plot to proove it, the car is owercammed
- g.t engineering
