Logging problems
				rbecue
Logging problems
This is probably a simple problem, but somehow I can't get the graph and the afr tables to work. Are there a simple explanation, or shall I post more information ?
						- IHaveTurbos
 - <font color=red>eCtune Authorized Dealer</font><br><font color=green>eCtune Authorized Tuner</font>
upload your .cal and log file, from the looks of the screen shot you were logging not in playback.    In playback is were you can see the a/f in those tables.
									Tim - Owner of Turbo Elements  www.turboelements.com    Dynocom DC-1800sz-SE
						I just got offline help from my supplier. It seems i've misunderstood the graph. The graph requires to load a logfile to display, it doesn't display realtime logged data.  And for the AFR overlay, the conditions set in the settings tab is not met. So thats the reason for no display there.  Thanks anyway
						not wiring
it's not in the wiring, I would think it would do that all the time if it was though, it only dose it after data logging for some time(towards the end), any other ideas?
