Cell trace hangup
eCtune Bugs and Fixed Bugs
greasemonkee
Cell trace hangup
Post by greasemonkee »
Very possible it could be my pc, but I haven't changed anything on it. Release 13, after logging 5+ minutes with data \"display\" enabled, if I put it in the background while still active, cell trace gets slow and locks. Did not happen on previous versions. I can't reproduce it exactly step by step though, but am working on it.
get step by step.. quad or single trace? interplation marks active?(black dots)
greasemonkee
OK got the basics: single cell trace, not sure what interpolation marks you are referring to? -Start program with loaded rom. -table view only (no graph) -connect emulator -connect datalog -enable \"display\" -open \"parameters\" (which will cover the display) -select sub parameter -click display again to put it on top -click parameter window to put display on bottom -click display again to put it on top Now she's locked. Data in display goes away. All datalogging functions are locked. Other functions are OK. -hit \"emulator disconnect\" (pc hard drive still sounds like something's connected at this point) -close program Program will not completely close, must use cntrl/alt/del to end program. I can get more details later, let me know what you need
This causes the cell trace to stop working?
greasemonkee
Yes, and everything related to logging. My PC is a P4 1.6 Ghz. Can't see why it would be maxed out, but could be...
can u test if this happen Key On Engine Off?
zex_cool
Post by zex_cool »
my did the same today BUT, it would show it on the 2D graph and not on the tables....at one point it would say connected but not log a single thing. im using quad cells.
zex_cool
Post by zex_cool »
calvin wrote:interplation marks active?(black dots)
how do you activate this ?
settings->grid/graph zex_cool you could reproduce with these exact same steps?
zex_cool
Post by zex_cool »
not sure. it only happened once and i just had my laptop hooked up. ill be tuning later tonight, ill let you know then.
greasemonkee
The above steps can be disregarded because I see now it doesn't reproduce EVERY time. What does turn up 5 out of 5 attempts and has the same reaction is this: (also works with KOEO and this is R14) -program start with .cal -close sensor data and display windows -connect emulator -connect datalog -open and close display window for about 2 minutes and guaranteed to lock. All datalogging functions are now disabled. -close program, ecu at 100% and program locked
cool i'll try both things... hope it does it here tooo
reproduced on the bench the lock and no update to display and grid... fixing now... i'll post if i fixed it
fixed
greasemonkee
Ooooh, I'm happy. :D Thanks
