Can you change the scalar edit steps?
				greasemonkee
Currently R13/R14.    The way it currently works - intentional or bug?    Select any cell on the table, select the same (or one right beside) row or column scalar as the selected cell. Select any cell in that same (or one beside) row/column again and then select the original scalar.     With one click the scalar goes into edit mode. A \"double click to edit\" only would prevent accidental scalar editing which I frequently do.    Thanks
only if u click the scalar rpm value or map value it goes into edit mode if i'm correct not if you click anywhere in the table
									Regards,  eCtune Team  eCtune Authorized Tuner  Location: Caribbean & Suriname    aim:calvinPGMFI  skype:ectune    We remote connect to your laptop if you have problems. Best support in the world.
				greasemonkee
				greasemonkee
single click to select.  double click to edit... that is how i programmed it if i remember correctly..  can some other people test this?
						Alright, I checked it also. Usually the single click selects and the double click will edit as they should. The only time it doesn't work correctly is when the exact steps greasemonkee has stated are followed to a tee, you must click on the user definable scalers though (gray), not the column(white). I can't get it to operate in single click edit any other way.
i did select cell  select the cell beside it  select the first cell  select the header(gray) of the first cell(currently) selected and it worked didn't go into edit mode    can u explain your steps better  use e.g. select (1,1)  column 1 row 1  then select (2,1) column 2 row 1  etc etc
				greasemonkee
				greasemonkee
        1. Select item in red circle.    2. Select item in blue circle.    3. Select item in red circle.    (one click all steps)      Now in edit mode
