2-Step is active all the time when enabled
eCtune Bugs and Fixed Bugs
no thinking had this same issue one and that was due to corrosion on the connectors and pins/plugs.
JBird20
Post by JBird20 »
looks like the cluster was the problem....everything works good now. Tried out the antilag and it starts to get going building boost at around 40degree retard and about 80 added fuel
40 deg is to much retard i think.. you end up with -6 deg... is this problem solved?
JBird20
Post by JBird20 »
yes the problem is solved...40 degree retard makes some big booms and makes like 17psi of the launch with a S258..maybe i should take it down alittle to like 33-34 degrees???
check what your fnl ignition is during anti-lag
JBird20
Post by JBird20 »
[quote="calvin"]check what your fnl ignition is during anti-lag[/quote] wut is fnl??
final
JBird20
Post by JBird20 »
final igntion is -6 during antilag
exactly what is your table? You retard basically everything you can.
JBird20
Post by JBird20 »
i just read on here that guys are dropping the timing that much...i mean i dont know wut u want to know?
that is how u built the most boost. i'll have some new anti-lag stuff shortly
JBird20
Post by JBird20 »
what will be the new stuff??
