Insert/Delete column
eCtune Bugs and Fixed Bugs
Delete column doesn't work as it should. It does delete the column but it also add a column at the end with the max load, so when you have 24 columns and want to add a column in the vacuum portion, you can't unless you copy& paste everything yourself 1 column to the right. Insert column messes up the table if you already have 24 columns in your table.
ttt :P
i'll check it out mate
