Insert column
eCtune Bugs and Fixed Bugs
Insert column
When inserting a column in the low map fuel (tested @ the 2nd column), the high fuel & ign map are not correctly modified. High maps gets the last two columns set the same. Inserting from the high maps do the same to the low maps.
I think this happens because the table is already expanded when you insert the column to the high map so the indexes in the table are not the same as the one you used in the low map and vice-versa.
Still there
how many columns are shown when u try this?
Any number of column will create a problem but differently. Just create a new basemap and insert a column (I insert a new column after 127mbar). As you can see, 302mbar column has change to 419mbar values. Everything from there is shifted 1 column to the left.
i see that you insert a column before 302mbar... and it add 2xx mbar and moved everything right correct?
Exactly but only for the lower cam, where I did the insert column, but for the high cam the column was inserted but nothing is moved to the right so it looks like it is move to the left. PS: I only show the high cam btw. The low cam is fine.
i'll double check it mate... in the morning i'll prob do an other release in a few days
confirmed!
and fixed
fixed in 2.2 r2 ? Cuz it's still there.
civic tsi check if this is fixed pls
fixed
