i'll verify that in the morning guys... i have it working on 62/63. does IGN cut only normal limiter work?
calvin wrote:i'll verify that in the morning guys... i have it working on 62/63. does IGN cut only normal limiter work?
yes ign cut with normal rev limiter works, no ftl or antilag but like on the first post, ign cut only with ftl enabled at a given rpm doesn't work. It over revs pass the set rpm for ftl and I think it's actually antilag but antilag is disabled.
It really really sucks not having Anti lag off the line with a big turbo :-/ Another track day lay to waste. I hope this update comes out asap. *edit* I just re-read that, Sounds like i was trying to be a dick, sry about that looonngg day in the gel-coat tent.
pro users can u test this with 0.0.2.2 r4 and rom 62 and see if everything is 100% i tested at it was good...
