Pls. help, ectune won't load....
eCtune Bugs and Fixed Bugs
butch11a
Post by butch11a »
i finished changing some settings in ectune and i saved the file when windows hanged, tried closing everything, nothing, so i had to turn off the laptop and restart. After that, ectune doesn't load anymore, tried forced update, didn't work either, tried deleting then updating, still windows shows that an error occured and that it won't load ecune... some more info windows xp service pack 3 dell inspiron 1705 i'll try to post the error report as soon as i learn how to post screenshots....
delete this folder C:\\Documents and Settings\\<username>\\Local Settings\\Application Data\\In4Tec_Solutions replace <username> with the login name you use in windows.
butch11a
Post by butch11a »
thanks Calvin, that did it, everything's ok now...
