program loading error
eCtune Bugs and Fixed Bugs
i get a microsoft error when i try to open ectune. Error signature: EventType : clr20r3 P1 : ectune.exe P2 : 0.0.2.2 P3 : 48fd1f83 P4 : system.configuration P5 : 2.0.0.0 P6 : 471ebf00 P7 : 1a8 P8 : 4d P9 : ioibmurhynrxkw0zxkyrvfn0boyyufow I have a race tonight!!! :o I have tried rebooting, running spybot, CCcleaner, force update (gives me an error that it cannot find base_roms) and i have updated windows.
ran spybot search and destroy again and now i can get it to partially load ectune. During the \"checking for updates\" phase and loading settings, it tells me it could not parse or find the settings file. Then closes ectune and gives me the windows error again.
utkuselamoglu
Post by utkuselamoglu »
98vtec wrote:ran spybot search and destroy again and now i can get it to partially load ectune. During the "checking for updates" phase and loading settings, it tells me it could not parse or find the settings file. Then closes ectune and gives me the windows error again.
there could be some problem with the settings files under your "c:\\program files\\ectune" folder. Maybe your "settings.xml" file corroupted. In this forum there is a post talking about your issue. In that thread shows how to reinstall ectune by deleting some files under ectune folder. I am not sure also.
utku selamoglu
reinstall you delete the settings.xml file in the settings folder
i'll check it out tomorrow. I never physically removed anything from my ectune folder.
i still have my settings folder and setting XML file.
White_Teg
Post by White_Teg »
98vtec wrote:i still have my settings folder and setting XML file.
I think Calvin ment for you to delete the settings.xml file. I would guess that somehow this file is getting corrupt. When you run eCtune after deleting it, it most likely creates a new one with the default settings.
calvin can you confirm that i need to delete settings?
White_Teg
Post by White_Teg »
from This Thread
calvin wrote:uninstall/reinstall do a force update... delete this too.. C:\\Documents and Settings\\<username>\\Local Settings\\Application Datafolder In4Tec_Solutions <username> your current login name
White_Teg wrote:from This Thread
thanks, i'll try that tomorrow when i get on campus.
woops
I uninstalled ectune and then reinstalled with the original setup function then use force update. opened ectune and got this error
it does allow me to open ectune tho
that is normal oxc for innovate needs to register
