fan control wiring
- utkuselamoglu
fan control wiring
hi, I want to use fan control option in ectune pro... but couldn't find a good wiring info with using a relay... does anybody have a picture for this wiring diagram... last year I have found a good info in honda-tech forums but couldn't find it in the forum right now... thanks a lot...
utku selamoglu
- utkuselamoglu
- utkuselamoglu
Bindegal wrote:There really is only one "option". It will only work in one way, you can´t pick and choose which way the output works/Allan
utku selamoglu
ground to thermostat housing/fan switch. fanswitch has 2 cables ground and signal to relay in fusebox. jump from ecu fan out to signal cable on thermoswitch.
- utkuselamoglu
correct. EDM/JDM car?utkuselamoglu wrote:Hi calvin thank you for your response... Than I don't need to use another relay for this.calvin wrote:ground to thermostat housing/fan switch. fanswitch has 2 cables ground and signal to relay in fusebox. jump from ecu fan out to signal cable on thermoswitch.
- utkuselamoglu
EDM.calvin wrote:correct. EDM/JDM car?utkuselamoglu wrote:Hi calvin thank you for your response... Than I don't need to use another relay for this.calvin wrote:ground to thermostat housing/fan switch. fanswitch has 2 cables ground and signal to relay in fusebox. jump from ecu fan out to signal cable on thermoswitch.
utku selamoglu
EITCP
a week ago i made this fan control to one civic. it is so easy that you wouldn't believe it. no wiring needed. just go to parameters-hardware settings-adiator fan settings and make it ENABLE, fan control output FANC /radiator fan relay A12)and put the temperature you wannt have fan ON. and that is all. no wiring needed and it is working great! PS: made on EURO P30 ECU (EDM)
- utkuselamoglu
Yes it is just like that but in some model of honda civic you can not do it. You have to wire it.EITCP wrote:a week ago i made this fan control to one civic. it is so easy that you wouldn't believe it. no wiring needed. just go to parameters-hardware settings-adiator fan settings and make it ENABLE, fan control output FANC /radiator fan relay A12)and put the temperature you wannt have fan ON. and that is all. no wiring needed and it is working great! PS: made on EURO P30 ECU (EDM)
utku selamoglu
