Staged Boost control not working
eCtune Bugs and Fixed Bugs
tried to use it last night, and it wouldn't activate any of the outputs.. I have to use GPOs to make it work.. Also we were using A12,A15 and A20.. For some reason eCtune wouldn't activate A20.. We tried to different ECUs.. It shows active in the datalog but the ECU output was not changing..
when i tested it/code it... it worked.. I'll test this afternoon. I had a car nos on Purge that was working
did you check this yet??
talked to dave today, he said that he was having issues getting A20 output to work as well..
i will have a look at messure it with a multi meter
Can somebody test a20? Chris when can u?
we did test with a meter, and it wasn't changing the state of the output even thought datalogging was showing that it was being activated.
i send u a new test bin
A20 works now..
those a20 only work or the manual boost controller
A20 works, not sure about manual boost forgot to test, I'll test that as soon as I get a chance this week..
Chris? Did u still test this? If the weather holds later i can test it... with a datalog...
deluded
Post by deluded »
it is a little more complex to set up, but when we were developing our 3 stage n2o boards years ago we set up our adapter harness to test op under driving conditions like this: back-pin a wire in at D20, solder 10k ohm to end of wire, solder 2 wires to other end of resistor, back-pin one wire to a20, back-pin other wire to generic 0-5V datalog input (eld, egr lift, etc) datalog should show 5V when op is inactive and 0V when activated. now you can test the op at 8k rpm and 20 psi (example) without staring at a voltmeter. i'm waiting for some ostriches to arrive or i'd test it for you today. hope this helps. edit: good way to test radiator fan control, too.
No, I think my outputs are messed up on my ECU.. I was doing a nitrous setup a few weeks ago and I tried A20 and A6 and neither worked.. But A12 and A13 worked fine. I tested A6 and A20 with a multimeter and it was showing like 4-5volts then when I inverted it would jump to like 7-8 volts it was really weird.. So I think it needs to be tested just to make sure with another ECU, which I am in the process of trying to find another P72..
OBDI P72, well, I have a fully converted P06 with OBDI IAB added...
