EBC duty cycle lookup maps -> Parameters locks up
eCtune Bugs and Fixed Bugs
open ectune, open rom, open parameters Duty lookup map in the target boost(psi) vs Duty Cycle table, single click on the top right cell; it's greyed out. Now; try to close the parameters window or do anything with it =) I love getting these interface bugs down
fixed validation bug
no more crash, but a little '!' circled in red appears when you click on it still; It's sorta out of place there =) the value is -15.95 and I believe this value is being reported by ectune as out of range after clicking on it....
first 5 columns should be >0 last five <0 see discription below
well; when I used the \"Setup PSI scalar\" button, the last field remained at -15.93 (top row, last col) I will change it =)
i'll cehck that
it should be like that e.g. 15|13|11|9|8|6|5|3|2|1|0|-15 that is how you want the table. That's why i made the setup button. It's interpolating so u need the min bound of 0x0h(-15 on 1.7bar mapsensor)
ahhh, well, when I click on it, it's a little ! like it's an invalid input... but it's funny cause the box is greyed =P
box is gray i'll check it later
Fixed; no bugs seen on this pane anymore; 0021r3t0
cool
