Crashes related to Graph
eCtune Bugs and Fixed Bugs
Here's an interesting one I found last night. open ectune open ROM open graph pane (should be empty cause no log loaded) close graph window open settings go to the \"Live plots\" tab change the TPS% modifier to whatever (lets say 70 or 88) then save. crash. It was a mess of steps when i found it last night, but I was able to narrow it down in the past few minutes when I though of it again. This is better than the 50+ steps needed origionally =P This bug was also present in 0021r2t1
zex_cool
Post by zex_cool »
same here.
thank i'll look into it
no crash here is that the exact step? from start up
No Crash...but an error here.
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at eCtune.Controls.ctrlLogGraph.““�˜�†‰�“() at eCtune.Controls.ctrlLogGraph.‹‘™ˆ’Ž™š“() at eCtune.Dal.Config.SensorUpdateDelegate.Invoke() at eCtune.Dal.Config.SensorUpdateEvent() at eCtune.frmSettings.““�‰‘‡�††(Object , EventArgs ) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
and u did this with those steps?
z31
Post by z31 »
With those same exact posted steps I also got the same error as Xenocron. No crash though, just an error.
yeah; everytime I go to check exact steps to get a crash, I will close eCtune, then reopen eCtune, and reopen ROM; etc.... If I make a mistake, or it does not work, I will close eCtune and start over.
Get the error too. There's an object that isn't referenced, probably the graph window. Also in Settings->Live plots, minimum is spell wrong. There's a \"i\" that shouldn't be there.
why i don't get this error. i'll check tomorrow again
i debug the routines a bit.. Can somebody send a screenshot of the graph window after this error is thrown?
The strange thing is that af you press \"ok\" the datalogging jumps 1 frame further and then it gives this message again, and again, and again. It stops after you stopped the playing datalog.
yes i found it. I ahd to close the graph window. Stupid me fixed btw
Gaskleppie wrote:The strange thing is that af you press "ok" the datalogging jumps 1 frame further and then it gives this message again, and again, and again. It stops after you stopped the playing datalog.
fixed y0
Yaaaaay! Hash one for the good guys!
