Found some 'bugs'...
- RoadXY
Using the web-update which came out like yesterday or the day before (12 of 13 march). Found the following things: - Download of the logger doesn't work. Steps: Type url http://www.ectune.com in addressbar In the site-map go to versions, datalogger Click download now and it give's me on 3 pc's and 3 different internet providers the same issue: an blanc page with an long url: http://ectune.com/LinkClick.aspx?link=h ... 69&mid=445 If you type in the addressbar: http://websrv.ectune.com/eCtune.Setup.Current.rar the download is started... - PA sensor incorrect in log The PA-sensor displays in the log an different value then in the data pane where the value is correct Wil post pic's shortly. - Show peak value's doens't work on newly created data display in the Display pane Steps: In the Display pane right click and select 'Add data display'. Right click on the newly created data display and set the type for instance as VSS. Right click on the VSS data display and click \"Show peak value's\". The right click and \"Show peak value's\" works only on the data display's that where standard displayed by the install of eCtune - Start up message to install .NET If you haven't installed .NET 3.5 eCtune give's an message you have to install .NET 2 and/or 3.5 I've tested this in an freshly installed Virtual PC XP environment with no .NET installed Installed .NET 2, tested and installed .NET 3 but eCtune keeps telling you have to install .NET 2 and/or 3.5
Re: Found some 'bugs'...
install 3.5 if it doesn't find the proper .net framew work it will give an error msg. It's not a bug i'll fix the link on the site. You can just press download on the front pageRoadXY wrote: - Start up message to install .NET If you haven't installed .NET 3.5 eCtune give's an message you have to install .NET 2 and/or 3.5 I've tested this in an freshly installed Virtual PC XP environment with no .NET installed Installed .NET 2, tested and installed .NET 3 but eCtune keeps telling you have to install .NET 2 and/or 3.5
Ok, doesn't matter to me, thought I just mention itcalvin wrote:install 3.5 if it doesn't find the proper .net framew work it will give an error msg. It's not a bug i'll fix the link on the site. You can just press download on the front pageRoadXY wrote: - Start up message to install .NET If you haven't installed .NET 3.5 eCtune give's an message you have to install .NET 2 and/or 3.5 I've tested this in an freshly installed Virtual PC XP environment with no .NET installed Installed .NET 2, tested and installed .NET 3 but eCtune keeps telling you have to install .NET 2 and/or 3.5
Yeah; the .net is probably because the 1.1, 1.1 update, 2.0, 2.5, and 3.5 need to be installed; not just the later of the groups. That's one crappy thing about .net; the updates never include all of the dependencies; only the new revisions/additions.
i installed a hardcoded check. I guess i can drop the 1.0 / 1.1 / 2.0 check But 3.5 is important otherwise program crashes
Adam Hopkins
