Found some 'bugs'...
- RoadXY
Found some more 'bugs'. Using the web-update version; logger type. - In the sensor setup there is in the description on the left side an strange symbol. I know that this symbol represents the return key but it looks a bit strange. (see attached picture). - In the 'Graph template setup' there are 2 sensors named MIL. One is always 0 (zero) and one follows the 'real' MIL flashes... - Also in the 'Graph template setup' if you have, for example, 4 te plotted sensors and if you remove the 3th the 4th is also lost if you select it using the arrow keys (holding the up-key). No problems when using the mouse though! Future request: is it usefull to have an sort of cancel button in the 'graph template setup' that when you accedently mes up you setting things won't be saved? Now, both the x on the upper right and close will save the settings. Just an question/suggestion
Makes perfect sense... the datalogging/recording routine is stopped when that error pops up. Then if you wait to click OK and datalogging recording is resumed you have an other speed;) As i said. r11 will only popup that msg ones and asked to lower column 1 mbar to a new value eCtune calculates.Is this by chance happening when the overflow error pops up? I notice the readouts freeze untill you click OK.... maybe this is the gap where I looked away, and when I saw it. I think I might be onto it... Look at the big empty space; happened during decel; then shows odd results and immideately is cruising at 40Mph??? Use with this .cal Let me know what you think! -Alan
Right on!!!calvin wrote:Makes perfect sense... the datalogging/recording routine is stopped when that error pops up. Then if you wait to click OK and datalogging recording is resumed you have an other speed;) As i said. r11 will only popup that msg ones and asked to lower column 1 mbar to a new value eCtune calculates.
