Possible TPS Tip-in enrichment bug
eCtune Bugs and Fixed Bugs
greasemonkee
Post by greasemonkee »
First of all, is it permissible to use a negative setting on the tps tip-in enrichment? I would like to get rid of some of this excessive fuel under light/idle loads and low throttle angle tip in. I have tried entering a negative number and instantly everything goes rich off the scale and floods. There is no going back and the calibration is permanently screwed. Any input sirs? Thanks
Are you using multiplier or percentage view of fuel correction settings. what do u see on a new calibration when looking at fuel multipliers?
greasemonkee
Tried both views, doesn't seem to matter. Guess I should rebuild the .cal from scratch and try.
greasemonkee updates?
greasemonkee
OK to use negative value. .cal file assumed to have been corrupt.
cool bro
