i remote connected to his laptop in his car. eCtune work, ectune runs on the ecu. no solid cell Horrible idle. with overall fuel trim -60% the afr is still 10.5 but idle is better. This is a stock honda engine with 240. -60% less fuel is not normall
Calvin, thanks for your assitance, you are cool .. I´ll check my injectors, timing, anf fuel presurre tomorrow. Hopefully this will fix my problems and I can tune my car. Also I´ll hook my datallog cable tomorrow or saturday. Just a final question on this : when you do -60% on fuel, the map do not change the values, then I suppose that this funtion is like reducing the size of the injetors for a -60% , but the time that injetors open is the same??
it multiplies the fuel value with 0.4 so removes 60% fuel you can see that in datalogging(injector duration)
