disconnect ostrich and look in device manager what port hulog is using. Disable auto-scan and select that port. baud 38400
Gaskleppie wrote:Is he changing the 2nd set of maps instead of the 1st?
Good eye... it does appear in the very first screenshot posted that he has the secondary maps selected. Which of course will not make changes to the car unless they are activated.
x2
No Sir, changes only tried on 1st maps, for shure. Maybe when I do the screen shoots I click on the 2nd maps by mistake, if you check all my screen shoots, just one is on the 2nd map.
You didn't disable auto-scan. Isn't the hulog plug backwards in the ecu? try that
calvin wrote:You didn't disable auto-scan. Isn't the hulog plug backwards in the ecu? try that
Was just going to ask that. Just disable auto-scan and then plug in the datalogging cable and check which com port opens and choose it in the software.
I´m lost, I never say that I have a hulog.. I don´t have any Hulog, just the Ostrich, but not is supposed that I can datalogg with it??? Or at least connect to the ECU to calibrate tps and track sensor info ???
an ostrich is an emulator, not a datalogger. No wonder you can't connect to the datalogging. You NEED a datalogging cable (hondalog, hulog, xenocron cable) to datalog.
jesus.............. You need an ostrich for emulation and hulog for datalogging(cell trace, tps cal, ign lock, everything)
