*FIXED* Bugs in afr overlay
eCtune Bugs and Fixed Bugs
civic4g
Post by civic4g »
Hi Calvin I've found some issues in afr overlay: 1-The option to \"Clear Selected Cells\" in Tuner menu is not working properly, when executed it clears all afr values from tables and not only selected ones. 2- When are made auto adjustments to selection and lets say that we are in low cam afr overlay, the afr values from selected cells/positions are cleared in both low and high cam. Let me know if you need more info.
i'll look into it
Add to list will be fixed in r9
confirm fixed?
civic4g
Post by civic4g »
confirm fixed?
Sorry for the delay answering you. Issue nº 2 is fixed. Issue nº 1 still not 100% fixed (works randomly) Check the videoclip attached
that means it clears only low cam sometime and sometime it clears high cam too?
civic4g
Post by civic4g »
This problem: \"When are made auto adjustments to selection and lets say that we are in low cam afr overlay, the afr values from selected cells/positions are cleared in both low and high cam\" seems FIXED This problem: \"The option to \"Clear Selected Cells\" in Tuner menu is not working properly, when executed it clears all afr values from tables and not only selected ones.\" it's NOT FIXED. In the video file you can see all cells being cleared when I asked to clear just the selected ones. I've seen this function working OK randomly but couldn't capture it in this video. For ex first time I clear selected cells works OK and the next time all of them get erased. I'll try to capture this in a new video.
civic4g
Post by civic4g »
Here is the promised video thats shows the randomness of the \"Clear selected cells\" function. http://filipedua.planetaclix.pt/updated.zip
thanks for the bug report. i reproduced it and fixed it... i'll leave the topic open so you can report it work on the next release
civic4g
Post by civic4g »
Now it's working good, fix confirmed. Thanks
