Bugs, ewwwww.
MADMAX
Bugs, ewwwww.
So far eCtune has worked great. Made 300whp on my D15B at 16psi of boost on piss 91 tane gas. Some things though. 1) The peak clear function does not actually clear the peak value in the datalog. You have to start and stop the datalog to actually clear it. 2) When selecting multiple cells with shift + arrow keys, every time you kit the arrow key it appears as if it reselects all of the cells. It makes it really laggy. 3) I mentioned this before, but I still would like to see the option of only viewing the 2D fuel/ignition graphs or simply having an extra window that just shows these graphs. 4) Maybe I'm and idiot on this one, but the only way I can view the datalog graphs (not Tuner live plots) is to record, save, and re-open the log. Is there something I am doing wrong to view these graphs? Thanks everyone.
1) double check peak again last time i tested it worked(clearing) 2)That is how it works for now 3)I have to code/change that(not important now, but on the list) 4)that is correct you can only view a saved log file. Not real time
I tried it and it won't clear. Press clear and then hit peak again, it will show the previous peak. Even better turn on peak and then press clear. It won't clear itIt will still show previous peak. Thanks for the tip nate.calvin wrote:1) double check peak again last time i tested it worked(clearing)
