update problem
I think you and me have similar problem bud. So I'll just be watching this thread and hopefully I can find a solution. I know the clicking noise is the main relay. When it clicks, datalogging locks up and stops. Here's a log file when it happened. Main relay clicked and datalogging locked and it stopped logging. Had to disconnect. The last part of the log, notice ECT and IAT 291.00*F MIL on and other sensors reading 0V but the car runs just fine.
- home.elf
- (437.36 KiB) Downloaded 280 times
I've had the same problem two or three times. I disconnected every thing and restarted ectune and the car and it worked fine after that. I've also had a problem when doing multiple data logs and telling it not to save and when i click no it would bring up another program that was opened on the start bar. If i clicked yes and saved it then then there was no problem.james25 wrote:I think you and me have similar problem bud. So I'll just be watching this thread and hopefully I can find a solution. I know the clicking noise is the main relay. When it clicks, datalogging locks up and stops. Here's a log file when it happened. Main relay clicked and datalogging locked and it stopped logging. Had to disconnect. The last part of the log, notice ECT and IAT 291.00*F MIL on and other sensors reading 0V but the car runs just fine.
OBD1 Turbo 86 Accord
