will not connect to ecu
- Garrett
you could not datalog, when ectune is not in the ECU
- Garrett
it doesn't matterfireztorm wrote:on the picture you sendt later in this post about the J1 i can see that you have a 304 number on your OKI. and the map in ectune is named: stock p28 304 USDM map. on mine OKI is stands: 208.. is this right?
I really question the chipping job... I have purchased countless Botched chipped ECU's, and all I had to do was clean the protective 3M film off the board, desolder all end-user soldered joints, refloat all of them, and the ECU worked fine afterwards! Most people don't take the time to brush or use a solvant to remove the thin waterproofing coat they put on the ECU and it makes it about 50x harder to solder it correctly. Also, scrutanize the installation of the ribbon cable for the ostrich, and use an ohmmeter to test it's connection to the socket, and all components installed with the chipping job. If you use a base .cal, with no modifications, and all sensors disable, KoEo you should see no solid CEL; if you do see a solid CEL: check connections make sure your ostrich is licensed make sure the upload of base rom and calibration goes through successfully check chipping job Solid CEL points towards hardware: either ECU or missing/switched sensors.
the ecu hasnt been chipped before. it was in factory condition before i bought the ostrich and hulog. here is pictures of my ecu. http://i38.photobucket.com/albums/e106/ ... G_2030.jpg http://i38.photobucket.com/albums/e106/ ... G_2031.jpg
if you look at the first picture on the link http://www.superhonda.com/tech/honda_ec ... mming.html you can see the ting marked on the attachment picture i do not have that. and the first picture on the link was when he had not touched anyting.
- 2000287474448754541_rs.jpg (54.49 KiB) Viewed 8509 times
