will not connect to ecu
Your ecu will function fine without that. Im not 100% sure what it is, but I have chipped many ecu's with and without it and they all ran fine.
fireztorm
Post by fireztorm »
okok.. but what parts am i missing now? i can see on the link he is using a chip.. i do not need that? i have ribbon cable and ostrich to use with ectune..
MM74HC373N-ND 1 The other chip that is reqired 1.0KEBK-ND 1 1K resistor 399-2127-ND 2 .1uF capacitors
fireztorm
Post by fireztorm »
ok.. thanks :) will try that
The other black thing is the baro sensor. Euro ecu's dont have that. Just disable it in the software and you will be fine.
baro or PA sensor (same).
