I share this theory, but when I set this option (ignition cut) for my launch control (TPS based, 3500 rpm, engage above 34% TPS) I get massive explosions/flames from the exhaust. Fuel cut, normal rev limiter reaction Fuel cut + ignition cut, normal rev limiter reacton. Now I can understand what happens, because the unburned fuel ignites in the exhaust manifold. Am I doing something wrong, rpm to low or something, or another setting? What is your experience with ignition cut during rev limiting? (I have a B16 with Greddy turbo kit, 450cc injectors)its always better to use ign cut or both. If you only use fuel cut, the engine is running lean during fuel cut. There is always some mixture left in the intake manifold what will ignite. ign cut will stop this.
Ignition cut
Ignition cut
Quote from Gaskleppie:
I have LC TPS based. And the standard values eCtune has in it. LC is more a "toy" for me.... I never used it on a customers car. Certainly not with the stock exhaust. At the JAF a few weeks ago there was a CRX with constantly was playing with his Crome-ish launchcontrol...It was annoying.... I demonstrated my lauchcontrol, few explosions, few flames, and he quitedcrx303 wrote:What settings do you use Rene?
Slijmbal?Did I mention already that eCtune is a very nice piece of software?
For me it's a toy also. I found some more mild settings now. And hitting the rev limiter before shifting is fun. Yesterday I had a guy sticking on my rear bumper on the A4. I gave him some fireworks and he backed off
What is a good reason to change management? My car was running very well on CROME, but it's just the hobby to learn eCtune and to have a lot more options
with anti-lag for full throrrle shift... that is extremly good. build/keep boost during shift. my race driver couldn't belive how good it is try it once
I have been too lazy to rewire the clutch switch myself
But I really think it will make the world of difference, because last night my friend was driving, he did some pulls past a speeding AMG... needless to say; I was using fuel+ign cut, and antilag had +3 fuel, with 50deg retard.. sucker didn't really pop, but that was honestly the first time to turbo would feel like it stayed in boost.... which I believe was partially attributed to the antilag retard... ause respool time was almost instant... not quite instant. It hasn't done this before
- [email protected]
no CAT; the right timing, and right fuel... helps if the exhaust is 2.25\" or bigger... Using IGN cut only: start with a smaller fuel value like 5, and 48 degrees of retard. 5,000RPM for now; add fuel one point at a time till it starts to get unbelievably explosive out the back... at some point, it will quiet down more... back off fuel for now... next adjust IGN +-5 degrees for best results. Now IGN is done; Changing it at the higher RPM's is alot harder to get real good results.... IMHO. Set FTL revlimit @ 7,000+ RPM Add/subtract fuel untill results are desired; remember small changes; and take your time... only rev it till you hear the second pop within a second or 2; try to be nice to the motor and give it a break now and then.... Sub note: If your tune is not correct at the boost/RPM amount of the maps; this will get drastically upset when you change the fuel there later (sometimes) because igncut provides alot of the fuel instead of thru antilag's routine...
