i just tryed ectune now and i get these error codes: Electrical Load Detector defective circuit or unplugged / defective sensor. And BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor. what could be wrong?
you just have to disable those sensors. Probably your ecu doesn't have them.
3500rpm it looks like SOLID cell not sure.. post cal and a log
it works now. i disabled the sensors. but i cannot set the settings in boost table. if i go into boost table and set the \"add 120% fuel per psi\" and \" retard timing 0,75\" settings on and then press apply nothing happens, and if i go into the boost table again then nothing happens to the settings.
