faded flashing CEL only when connected
It would only start to be seen when you are under light acceleration then go away if you hit the gas more or let off the gas. The longer i stayed under acceleration, the brighter it got and the faster it flashed. The light turned off when i unplugged the ostrich and hulog. using version R6 http://s23.photobucket.com/albums/b376/ ... D00009.flv
it just worried me because it changed the tune while connected. I havent actually needed to mess with my tune for the last few months until i saw something small that i needed to fix. Went in to fix it and everything changed. I got things where it needed to be and unplugged the computer. Everything went crazy lean so i think the cel was doing something in the background. Uploaded the original cal and it all went back to normal, tune wise. thanks calvin.calvin wrote:you have some problems too sometime!... w'll figure it out like the rest
i guess its possible. I'm running the amount of NA load columns which would be about a 3 bar map without load scalars. Just added columns so there wasn't big jumps in fueling. i'll try a prior cal and let you know.
