No EBC, please help
[email protected]
No EBC, please help
Post by [email protected] »
Trying to get ebc to work. Was using a jdm p30. Chipped a usdm auto p28 to use EBC through auto lock-up (A17). Could not get EBC to work. Checked output to solenoid (key on engine off) with mbar at 43 for EBC activation and wastegate, had no voltage output to solenoid. Thought maybe auto lock up circuit didnt work, so took another p28 and installed 5151 into IC16 and diode into D13. Same thing no output. Can someone please take a look at My .cal and help me. Thanks Jeff
4GSRtopIGNadjfuel1.cal
(8.18 KiB) Downloaded 345 times
Jeff Augusta GA 88 CRX JRSC B16
[email protected]
I have checked the solenoid and it clicks when 12v positive is applied to the wire i have going to A17.
it's not your cal it should be hardware. Did you follow the manual to add the hardware and sk1515?
[email protected]
the first P28 was an auto. the second one I used had the sk5151 and the diode installed.
[email protected]
pin was messed up in A17. solenoid clicks now. will play later. hated 6psi Thanks Jeff
