help xml document
tommy954rr
help xml document
Post by tommy954rr »
I try to open ectune form desktop icon then it starts to load then the force update pops up. Then after few min. goes buy xml document (1,304) error. I read the post about saving xml to desktop and deteling the one in ectune file then re-save it. I just really don't know what to do . thanks tommy
Just a noob.
Maddog20
Post by Maddog20 »
Are you talking about the Liscense XML Doc?? if so then: save XML file to Desktop Cut and paste to Ectune Folder.
tommy954rr
i have tried that. i left clicked and dagged it - right click and drag it and cut and paste. everytime the same error pops up. but thanks for the help it is most needed
Just a noob.
the problem he is having. The webupdate fails with an XML error.
tommy954rr
i finally got it to work sunday night. I logged off the internet tried it again and bam it was up and running. Hooked everything to the car datalog worked the onlything i had was this jit debugg problem for the ostrich. But i reading up on that now. But Thanks for all the help. tommy
Just a noob.
post a screenshot of the error
tommy954rr
i have the user account control off
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous) at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args) at h&#155;&#152;&#149;f&#134;�&#135;b�1&#155;&#158;�&#151;o&#158;�j.x&#159;2&#146;5p�&#134;j��l&#151;&#159;&#153;&#151;7c&#152;.&#139;&#152;�&#149;&#149;&#134;&#156;&#150;�(Int32 ) at mde&#155;5g&#138;bknugv48&#159;qa&#147;.&#149;3&#139;&#159;t&#159;&#138;afx&#142;wti&#150;�&#135;&#139;1.&#146;6&#146;5jm&#138;d&#139;v4&#159;&#147;&#146;&#147;&#155;my&#149;.q98xp&#140;&#138;cm&#159;8k�my&#142;&#153;c�.Invoke(Int32 ) at mde&#155;5g&#138;bknugv48&#159;qa&#147;.&#149;3&#139;&#159;t&#159;&#138;afx&#142;wti&#150;�&#135;&#139;1.&#140;&#140;�&#151;�&#153;&#136;&#142;&#137;(Object , ProgressChangedEventArgs ) at System.ComponentModel.BackgroundWorker.OnProgressChanged(ProgressChangedEventArgs e) at System.ComponentModel.BackgroundWorker.ProgressReporter(Object arg) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3074 (QFE.050727-3000) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- eCtune Assembly Version: 0.0.2.2 Win32 Version: 0.0.2.2 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- startup_lib_net_2_0 Assembly Version: 2.0.0.0 Win32 Version: 0.0.2.2 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3074 (QFE.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Security Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Security/2.0.0.0__b03f5f7f11d50a3a/System.Security.dll ---------------------------------------- System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll ---------------------------------------- System.Deployment Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll ---------------------------------------- Interop.MTSSDKLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/eCtune/Interop.MTSSDKLib.DLL ---------------------------------------- eCtune.XmlSerializers Assembly Version: 0.0.2.2 Win32 Version: 0.0.2.2 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.XmlSerializers.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging=\"true\" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Just a noob.
tommy954rr
Just a noob.
screenshot.. and exact steps what you do to get this error. then i can solve the bug and fix it.
tommy954rr
every step.. I click the desktop icon ectune the program opens. I go to file- open I have a basemap saved. Click on to the basemap I want. Click the emulator tab. Go down to connect the ostrich. Then in green letters it states Connected. Then if I click verify rom or put base rom - uplaod any of those i get the jit debugging screen. I do have the User Account Control turned off i tried with it ON and then I could not even get into ectune at all. So I turned it back off. Thanks.. Tommy
error jit debugging.jpg (213.59 KiB) Viewed 7740 times
Just a noob.
if you don't verify first and just upload?
tommy954rr
Yes I am a noob!!! I have it so far to verify the rom and to uplaod. I dont have car with me at this time. I guess the problem was Ectune is saved into programs file I had the basemap saved into the documents file. I created a new basemap went to the program file open it up then found the ectune open it up found the folder that stated base_rom saved into that. Then did the steps and everything checked out good. No errors at all. So yes stupid me. But please bare with me I do live in SOUTH GEORGIA. Thanks for the help.. Tommy
Just a noob.
