ectune won't load
butch11a
ectune won't load
Post by butch11a »
Two or three weeks ago i got my laptop back from repair, they said it was the video card, so its fixed now, now i got an NMI parity check error, so i checked my ram, seems to be plugged in. Now i ran ectune and it started, checked my rom, parameters, everything's the same, when i closed ectune, i got the NMI error again, so i restarted the laptop and everything starts ok, when i opened ectune i got an error, ectune has encountered a problem...i tried deleting in4tecsoln and reinstalled ectune still same error, it may be possible that my 2 ram cards got interchanged in their slots, could that cause my machine id to change also? windows xp sp3 inspiron 1705
butch11a
Post by butch11a »
nvm, finally got it to work, tried switching the rams around and deleted in4tec, and reinstalled again, now its working again....sorry to bother you....
it's it probably the settings folder
butch11a
Post by butch11a »
when i got the nmi parity check error i was checking out the parameters when the laptop screen turned blue and crashed, after that it wont load anymore. now i got ectune working again, but occasionally i'd still get the nmi error, i know this isn't ectune related anymore but if it crashes while ectune is open, it won't reopen unless i reinstall and delete the in4tec file.....
