ectune broke again
kyhatch01
ectune broke again
Post by kyhatch01 »
i just ran force update now i cant even get ectune to open and wow always happens when i need it . a small box the size of the force update opens then dissapers and thats it i ran forceupdate again and still does not work
Orthello
Post by Orthello »
Do you force update while eCtune is running?
kyhatch01
Post by kyhatch01 »
no
Civic VTI-Turbo
Post by Civic VTI-Turbo »
Same problem here!
van Drie Tuning eCtune authorized tuner the Netherlands
boostedeh2
Post by boostedeh2 »
I just forced update and now I can't open ectune either, its the first time this happened. Believe it has something to do with the ectune.exe it shows a pic of a exen window icon instead of the ectune icon.:(
Same problem here. When I started eCtune in dos it give's me the message: \"Program to big to fit in memory\". I'm sure i've got enough memory (2gb free, 1Gb used).
Error msg in dos
Error msg in dos
fout ectune.jpg (30.84 KiB) Viewed 32865 times
stenseltizm
Re: ectune broke again
Post by stenseltizm »
kyhatch01 wrote:i just ran force update now i cant even get ectune to open and wow always happens when i need it . a small box the size of the force update opens then dissapers and thats it i ran forceupdate again and still does not work
I had just updated first time in months monday and it worked (didn't touch the car all winter), today I update and get this same black box that pops up for a couple seconds then nothing.
b20vtechb
Post by b20vtechb »
same problem here too!!!
Civic VTI-Turbo
I hope this can be fixed easely! I need the computer tomorrow... :)
kyhatch01
Post by kyhatch01 »
every time i need it its seams to be f**ked maby going to get hondata
2bfi
Post by 2bfi »
Same problem here. When I updated on Feb 25, it worked perfectly. Then, there were some fixes by Calvin and he said to force update. After the force update on Feb 26, I get the program too big to fit in memory problem.
update again. I updated yesterday and for some reason the exe got damage. The file was repaired after being online for 1 hr.
Works again! :D
kyhatch01
Post by kyhatch01 »
thanks
stenseltizm
seems to open fine for me now. It doesn't even crash anymore when i change units.
