timing syng issues
racepak
timing syng issues
helo everyone I tryied today to sync my ignition advance. i set up my snap on timing light and got the distributer into the original OEM mark. i cranked up the engine using setup: base timing: 16 timing lock: 16.5 in my timing light the number got to be around 26-28 degrees. i turned to distributer to get the maximum retard, the timing light indicated that it is now at 21-22 degrees. i set the timing lock to be at about 8 degrees and now it has show about 16-17 degrees. it seems like i am missing something, it's looks like i need to write 8 degrees when i want 16 and it's just funny. any ideas? setup is a d16z6 oem td42 dizzy 75.50 vitaras eagle rods 59300 cam aem cam gear set to 0 thanks
my initial thoughts as well. either that or your dist is for another head... or you have a different cam gear installed than you should. do all 3 bolt holes line up for the dizzy?Bugermass wrote:your timing belt is probably off a tooth or so.
sj-performance
Hybrid96EK
If you're maxed out the physical adjustments and still 8* advanced, and 101% POSSITIVE that all the parts are correct - it has to be the timing belt that's somehow off a tooth. There's no other way you can accidentally throw it off by that amount, unless your distributor shaft happens to be bent in 2 specific places, both in exact & opposite amounts. As mentioned above, a Y7/Y8 gear on any other D-series will throw off timing, but usually by 4*. Did you (*or previous owners*) deck the head and the block by some crazy amount?
hi guys.... to answer your question.... dizzy is matched to the head (td42 on a d16z6), all the bolts are aligned. the block is milled just a tad (cant remember how much) i think its the cam gear too, if the y8 cam is advanced 4.25deg over the z6 ineed to retard the cam 4.25 degrees. that means it will be retarded 8.5 over the 22-24 degrees i see now. that means ill see 14-16 degs at the cranck, right ??? thats pretty much what i under stand from this thread: \"y8 cam w/ z6 sprocket: advance 4.5 degs. If z6 cam with y8 sprocket: retard 4.5 degrees\" http://www.d-series.org/forums/showthread.php?t=41363 thanks
