Unexplicable Fuel Cut
Turbo3GLude
Post by Turbo3GLude »
I am experiencing Fuel cut for unknown reasons. I have datalogs attached can someone look at them? Currently I have boost fuel cut set a 2psi and while in neutral reving to 3500 I experience fuel cut and I am not sure why. Can someone take a look at my datalog and chime in here. Thanks.
LudeLogFuelCut.elf
Fuel Cut at Frames: 270 & 672
(174.75 KiB) Downloaded 325 times
You have to put the .cal file here also. We cant read your .elf without it.
delsoldude88
Post by delsoldude88 »
here is the cal
prelude new.cal
(8.18 KiB) Downloaded 284 times
Regards, eCtune Team eCtune Authorized Tuner Location: Chicago,Illinois,United States
Civic VTI-Turbo
Post by Civic VTI-Turbo »
Which \"rom\" did you use? .62 or .63?
van Drie Tuning eCtune authorized tuner the Netherlands
Piv
Post by Piv »
I had the same issue on saturday Trying to map a B16 ITBs with cams, pistons... And impossible to rev higher than 3500rpm If anyone got an idea ?
Rony Civic ITB remap.bin
(32 KiB) Downloaded 328 times
itb is different play with mbar and tps in fuelcut settings
Piv
Post by Piv »
Yes but as you can see the fuel cut is setting to 1800rpm, is it possible to happen everytime at 3500 with this setting ? I went back to England and the guy is in France, he should come next few weeks to get the car done but I need to know where its coming from :cry:
try rom .62 I think its that ICM thing..
ICM checkbox was removed from 63. 3500 can have to do with tps and or map
my CRX did the 3500RPM thing the other day on .63 I went back to .62 it worked fine.
Piv
Post by Piv »
Bugermass wrote:my CRX did the 3500RPM thing the other day on .63 I went back to .62 it worked fine.
You were write, I sent an other EPROM with a .62 on it and it worked fine Thanks :P
racepak
Post by racepak »
sry forthe dumb question but, what do you guys mean by .63 .62 ??
Adam Hopkins
Post by Adam Hopkins »
rom version
