weird idle problem with pt 880's
				sj-performance
I have had the same problem for sometime, I just cant get my car to idle properly.....  The car will only idle without bucking and poping when I have it extremly rich like in the 11-12afr anything higher and it starts to misfire... I have tried every combo with the battery offsets,egt and iat...when the fan comes on it will idle fine untill it shuts off, and its not just me I have a couple friends that are good at tuning and it  leaves them scrathing there heads.... So far I have checked everyhing mechanical,made new ecu, new conversion harness,grounds, sent the injectors back to p.t and had them checked and cleaned etc etc.... I have no clue as to why it is doing this maybe I am missing something... I am using 880cc precision injectors,boosted b18c,gm 3 bar map, 255 walbroh pump, aeromotive regulator... Please help.....The only thing I havent really checked was the pump, I do have an extra but the fuel pressure looks good......
				sj-performance
				sj-performance
				sj-performance
				sj-performance
				BlindFashion
its not gonna hurt anything to let it pop.. Id rahter have the poping than run it really rich for a smooth idle..
				Adam Hopkins
+1 As long as the car is not shutting off or wanting to die a little popping is better than 11.5 a/fs at idle. You do not want to wash the cylinder walls down with gas and possibly cause damage.Bugermass wrote:its gonna gonna hurt anything to let it pop.. Id rahter have the poping than run it really rich for a smooth idle..
Regards,  Adam Hopkins  eCtune Team  eCtune Authorized Tuner  Location: Murfreesboro, Tn, USA
				BlindFashion
Bah, Its really really hard to wash cylinders down, andd 11:1 wont do it. 40k and 4 raced years later I've never had my bottom end apart and in the winter she idles right at 11:1 Doesnt eat oil or smoke. 693WHPAdam Hopkins wrote:+1 As long as the car is not shutting off or wanting to die a little popping is better than 11.5 a/fs at idle. You do not want to wash the cylinder walls down with gas and possibly cause damage.Bugermass wrote:its gonna gonna hurt anything to let it pop.. Id rahter have the poping than run it really rich for a smooth idle..
