Latest Ostrich 1&2 firmware
Updating the Ostrich firmware is necessary to get the PRO and DIY versions working! Only with this firmware its possible to obtain a licence. Ostrich1 firmware: http://support.moates.net/2008/09/16/firmware-updates/ (the old big one) Ostrich2 firmware: http://support.moates.net/2008/09/16/firmware-updates/ (the new small one)
Here some image's of the different versions to visualy identify yours...
Ostrich version 1
Ostrich version 1
Ostrich v1.jpg (48.9 KiB) Viewed 66231 times
Ostrich version 2
Ostrich version 2
Ostrich v2.jpg (84.09 KiB) Viewed 66231 times
zex_cool
Post by zex_cool »
not sure if i should post in here or not but here i goes. i got the license for eCtune and now im trying to install the firmware and im not having the best of luck with it. -i used the moates updater but its unable to locate the ostrich. -tried to manually enter the location of the firmware into the moates updater but i get a pup us saying \"firmware package not intended for this hardware.\" i have an ostrich 2 with ostrich 2 firmware form this thread. -i also tried to the \"normal\" windows wizard but when manually putting in the location of the firmware it says \"the location you have specified does not contain any device information files.\" im stomped.
sounds like you might need to email moates....
zex_cool
Post by zex_cool »
JaredKaragen wrote:sounds like you might need to email moates....
no, i had the same problem when i first got ectune, but its been a while since then.
If your USB comms drivers are working properly (PLEASE use the latest version off the FTDI site!) there really is nothing we can do here. It´s a Moates app for a Moates part. I might try using another laptop and see if it makes a difference somehow. /Allan
zex_cool
Post by zex_cool »
that was it, old driver just needed an update. ostrich works now. thanks.
nce
Post by nce »
anyone know where i can get the updated firmware the link isnt working
relic1
Post by relic1 »
right click - save link as ... works perfectly for me. utility - http://www.moates.net/documentation.php ... tion_id=22
nce
Post by nce »
there isnt any for the ostrich v1 only the newer one will that work with the older ostrich too
uploaded to server again
