will ectune have problems with AEM IAT sensor?
				combz
I am just wondering if ectune will have any difficulties for some reason reading the AEM 30-2010 Intake IAT temp sensor?
well, if you zero out your upper temp range for IAT.. then just tune it...   if you notice anything out of the ordinary on a cold startup that is just left sitting, then you can tune it out if different...    It may be different.. I would imagine possibly so.
				rschoener
I am going to try one on our turbo car. Just like Jared said I'm just going to zero out the current settings and re adjust.
									Regards,  eCtune Team   eCtune Authorized Tuner  Location: Atco, NJ, USA  Randy Schoener  RSTECH  www.rstech-racing.com
						i was just wondering if perhaps there could be something like there is for widebands where you input voltage corrections based on the wideband lookuptable the manufacturer provides.    But its AEM, its not like there are 15 different reputable IAT sensors out there. Might be good to have a choice for IAT type? i dont know.
Perhaps he means that its way to deep in the software to be able to change it and its not worth it.  There are already to types of oem honda iat sensors. Choose the one you like and use that one.  The place to put the IAT sensor is way more important then the sensor it selves.
						okay i see what you mean.    but he's calvin he can do anything?    haha, but i mean its a sweet sensor..it comes with an aluminum weld bung, and the sensor is threaded. It's perfect to throw on a car's charge piping or intake manifold.    The reason i bought it was because i didn't want to go through the hassel of having to try to get a junk yard to rip and OBD1 sensor and plug off a car. My OBD2 style one is just held in by a rubber grommet, and i cant exactly put that in my charge piping.Not unless i want a boost leak anyways.
						Calibration for the AEM sensor.  Could be useful at some point        if the problem is that you cannot find the IAT stuff in the factory obd1 code, then yeah i see a problem. But otherwise it would be like any other thing already setup..you find what the stock values are then you use a scalar table.    I'm going to try the sensor anyways, in hopes that most IAT sensors use the same basic resistence conversion chart.(Edit: this is probably a bad idea..i just found out that most OEM sensors use different conversions..i searched online and could not find an OEM honda IAT chart like the AEM one i posted above
  )    I'll also call AEM and ask them a bit more info on it.
						Code: Select all
Calibration:  Temp C    Temp F    Resistance (Ohms)  100        212      185  70         158      450  40         104      1.8K  20          68      3.4K  0           32      7.5K  -20         -4      25.0K  -40         -40     100.7K
