ARF CHANGE with SAME Bat Voltage and ECT, IAT
b20beast
Post by b20beast »
I have a problem with Consistant Idle ARF. At Idle around 850rpm The Afr Fluctutates The Battery Volt is the Same ECT and IAT Are the Same Goes 14.48-14.98 AFR
AFR
AFR
combz
Post by combz »
man..thats such a small blip in the afr..that happens for a split second..and its at idle or vaccuum..its nothign to worry about. there are other factors that could make that happen too
b20beast
Post by b20beast »
what are some other factors to consider? How consistant should the afr be?
greasemonkee
Post by greasemonkee »
occasional misfire and or ecu shifting timing to compensate -> afr twitch
Adam Hopkins
Post by Adam Hopkins »
You will never get it to be 100% rock solid. It is not Calvin's, eCtune's, or your fault. I have tuned vehicles on about 15 different types of software and I ALWAYS see small fluctuation in afr's at idle. Do not get me wrong, a small blip from 14.4 to 14.8 is ok, but if it is jumping a whole point or something more extreme then it is usually a compensation table you need to adjust.
b20beast
Post by b20beast »
thanks everyone
that is good.
