aem wideband, truboost, oil press gauge on same ground??
				tandrew21
will having my aem wideband, aem truboost gauge and oil pressure gauge on the same ground affect my wideband readings.  AFR seems to be pretty accurate but i just wanted to make sure... Thanks.
				BlindFashion
- VTEC Inside
Get a motec plm, they will run at 9 volts with the noisest electrical system in the world and it still performs flawlessly..  I had a car a couple days ago and had my lm1 on it.. Stupid lm1 would start glitching really bad after about 5 grand and had to re warm up every time I started the car cause the battery had a bad cell.. Finally I got fed up and tossed the motec in there and it worked flawlessly the whole time, it even kept the O2 hot while key on engine off and only at 9 volts of battery power.. Motec for the win everything else is crap
				BlindFashion
Interesting, My PLX unit i've used for 3 years works just as goodBugermass wrote:Get a motec plm, they will run at 9 volts with the noisest electrical system in the world and it still performs flawlessly.. I had a car a couple days ago and had my lm1 on it.. Stupid lm1 would start glitching really bad after about 5 grand and had to re warm up every time I started the car cause the battery had a bad cell.. Finally I got fed up and tossed the motec in there and it worked flawlessly the whole time, it even kept the O2 hot while key on engine off and only at 9 volts of battery power.. Motec for the win everything else is crap...
