tps and map sensors not reading
KIT
Post by KIT »
I have a problem, when datalogin, the map sensor reads 5.0 volts on idle, and no change at all, and tps shows 0%, no matter if I'm pressing the gas pedal, and voltage stays with no changes at 0.47. car is smoking black, please help me asap guys, :evil: :evil: :evil:
ls_dx
Post by ls_dx »
Did you calibrate TPS?
KIT
Post by KIT »
ls_dx wrote:Did you calibrate TPS?
I do
non-vtec
Post by non-vtec »
you might have the tps and map sensor connectors mixed up.
KIT
Post by KIT »
non-vtec wrote:you might have the tps and map sensor connectors mixed up.
No Sir, not mixed up cpnnectors. This starts since ectune crashed when I was adjusting my car. And now the map I was using has 11.24 psi in all the columns, no vacuum columns at all. Wierd
No idea what happened, but you can try to upload an older file.
try upload+baserom and ectune crash would likely not cause the tps/map not to read on KOEO
KIT
Post by KIT »
calvin wrote:try upload+baserom and ectune crash would likely not cause the tps/map not to read on KOEO
I´ll try. But map/tps are not reading also with the engine on
they should first read with key on engine off. map sensor should be arround 1024mbar. tps 0% and moving if you play with throttle.
b20beast
Post by b20beast »
If you can use a Volt Meter to check voltages from map and tps to verify its not mechanical/electrical
KIT
Post by KIT »
problem fiex, tps was broken on the inside. change for another tps, did the calibration and done. Thanks guys
good!
