Injector kill used as anti theft?
				MantisX
Just wondering if I could kill the injectors with ectune? Could I save a bin like that and it wont start again until I change it with ectune?    Is the anti-theft features coming soon with ectune?    Thanks  MantisX
				greasemonkee
				greasemonkee
				spraymysol
Correct it's just not implemented yet, but hopefully for everyone who's waiting on it, it should be soon.spraymysol wrote:Anti start is a Pro feature right? It is grayed out due to it not being implemented yet correct? Anti start had better be a pro feature because its the whole reason I bought eCtune, lol! Well its the one feature that made me chose it over competitors. I'm pretty excited to see it released.
- VTEC Inside
They certainly DON'T work well when you're using them for something else. There is another option. Get a 512k chip, get a tuner to burn your good CAL to one part of it's memory, and a "bad" zero'ed out CAL to the other, and use a 2-timer to switch between. Before I had proper secondary maps (cr0me pr0), I added a pin in my harness where nothing is in the ecu, desoldered that pin from the ecu board, and hooked it to the 2-timer. The old method for an effective kill is to wire a switch to the main relay's ground. It kills injectors, ecu, and fuel pump - you get nothing but a solid CEL. You also want to relocate the main relay far up into the dash so it's impossible to jump it.greasemonkee wrote:Secondary maps works well for this. Set the idle area of the map and zero the rest out. Thief cranks car, but doesn't go anywhere.
