datalog and other stuff
chepetrueno
Post by chepetrueno »
hello, i opened a thread in general comments, but here are my troubles, the car starts but only revs to 4000 rpm, and demon will connect to my laptop but wont datalog what can it be, i tested conection in settings and said demon found in com5
Somthing is wrong with your socket, or how the demon is plugged into the socket, sounds like the ECU isn't reading it. Double check everything..
chepetrueno
ok ill check that out tomorrow, anything in particular i should look for, or should i desolder the whole thing and resolder it
just make sure its all the way in there and that the pins are lined up prperly, also you did put the 74HC chip in place too? I've had a couple ecus come in that were missing this.. Somtimes the demons feel like they are all the way in but they are not.
chepetrueno
ok thanks, 74hc is in but maybe there is a bad solder in there ill check anyways
check wiki.ectune.com it give u the status of the leds how it should and should not be...
chepetrueno
i will check the led status, but in the meantime here are some pics of the setup
chepetrueno
well i tried as the wiki says and the leds are working normal, red led turns off when emulator is conected and the green one is flashing, could this be an issue with the license? i had another demon installed before this one, i un installed and put the new demon inside it do i need to send calvin the request for another licence to be there?
see wiki.ectune.com trouble shooting guide... problem between demon and ecu -cable -j12 -no rom uploaded http://wiki.ectune.com/index.php/Datalo ... on_version
chepetrueno
should the j12 be fully removed? also i checked the cn2 port and it looks like its welded properly, the last thing would be the cable also does ectune pairs up to a certain demon, i had another one, and with the last one had no trouble, could this be what is giving me trouble?
it looks good you entered the demon serial number right?
chepetrueno
the number that is on the underside of the demon, i mean the opposite side of the battery? i entered the demon licence that xenocron sent me
yes j12 needs to be removed completely
HeroOfTheDay
Post by HeroOfTheDay »
I am having the exact same issues. Is this because my registration information hasn't been returned yet? I just registered today, and was told I need to place an XML file in the eCtune directory. Is that correct?
HeroOfTheDay
My red LED does not turn off when I connect to the emulator. J12 is cut, I uploaded a baserom+calibration, and the CN2 cable is plugged in correctly. Why is the LED still on?
