AFR readings not displaying
hyisbm
Post by hyisbm »
I spent most of the day playing with ECtune and just cannot figure out what the problem is. I load up all the settings and everything seems to be working but after I save a log file, and when I try to play it back I don't see any AFR readings in the cells at all. The file plays and different cells are highlighted but no numbers are displayed. Any idea what the issue is? my setup is: D16Z6 550 Evo injectors Motorola 2.5 map sensor Thanks
review the graphs and flag spots in the graphs that need changes. Click your flags and then go back to the table and the cells will automatically be highlighted and it will show what the AFR is and all the data you need to know. The overlay only works in real time. edited to delete false info. SICK FTL
hyisbm
Post by hyisbm »
is that the reason why I also can't click on the overlay options? I'll give that a try. really appreciate your help, I contacted Calvin but he said he's going to be pretty busy this week.
hyisbm wrote:is that the reason why I also can't click on the overlay options? I'll give that a try. really appreciate your help, I contacted Calvin but he said he's going to be pretty busy this week.
what do you mean by overlay options?
hyisbm
Post by hyisbm »
hopefully I remember this correctly since my brother was the one messing with it and just told me about it. He said he can't even click on the overlay tabs to look at it. They are all just grayed out.
you mean this?
overlay
overlay
hyisbm
Post by hyisbm »
yes, those tabs.
i do not believe the PRO version has the ability to use Overlay 1,2,3. IIRC only tuners and dealers have those options.
hyisbm
Post by hyisbm »
okay, I'll have my brother look at it later. We did kind of thought that was what we would have to do but figured that would be extremely time consuming and there has to be another way.he's much more comfortable with Crome which is why he's even more frustrated.
the GUI is not much different than crome, however, everything works and you dont have to worry about installing wack plug ins. datalogging is about reviewing the graphs and referrencing to the tables. The overlays do not show anything after opening a datalog for review.
hyisbm
Post by hyisbm »
I think he just likes the idea of being able to look at the whole table at once and just select changes. Not having to switch back and forth.
marshall.hagen
Post by marshall.hagen »
My PRO version allows me to see AFR logged in cells. If you enable cell trace, datalog, then open the datalog, open A/F Reading (F11) you will see the AFR in each cell that the trace touched.
wow, i guess the flu i have has really gotten to my head
