wth? all the sudden ostrich license error?
danz
Post by danz »
Been using ectune without any problems, then all the sudden tonight i try to raise my boost cut to try and hit 10s and ectune tells me my license doesnt match? it worked fine all night, then THIS?! whats wrong here.... it was really bad timing to be locked out of making changes to my tunne..... the pass before it happened, the car seemed to almost shut down right at 8000rpm in 1st coming off the line
danz
Post by danz »
found this... seems to be an ostrich issue... hmm http://forum.ectune.com/viewtopic.php?t=1619
we are working on this really hard
ok... so far what we know.. ostrichReset app did not remove the serial. The updated version removes the serial number eCtune.. eCtune doesn't have code to write a new serial if the serial is not blank(new ostrich) Craig moates and I are working on it very hard. I'm gonna test tunerRT and crome if they reset the serial.
