Message connecting to emulator (demon)
civic4g
Post by civic4g »
Hi i'm getting this message everytime I connect to the emulator since the last update. Any help?
sIrK
Post by sIrK »
Hi, i have the same problem, when connect to emulator and when connect to datalog. I have problems with connection too. I have to unplug the usb, and plug in again and then do a connect. After this the ectune shows again the message of serial. All this problemas after update to last version. I have a friend that have the same problem.
eCtune Pro & Demon rOolez! 92 Civic Turbo-Vtec at 1.5bar 300hp 93 Civic B18Dohc-Vtec Na 230hp Chrysler Neon 2.0L 16v InsanePower!
2bfi
Post by 2bfi »
I have that exact same problem too. It happen when I do any of the following: Connect, Disconnect, Datalog, Disconnect Datalog, any command that results in a real time update/access to the Demon.
Vtec6000
Post by Vtec6000 »
I am also having this same problem. Started happening after latest update. Any help with resolving this Calvin?
sIrK
Post by sIrK »
Any solution for this problem?
Tuned a car this weekend and had the same issues with his Demon.
TheGuardian
Post by TheGuardian »
Same here, Im wondering if it has anything to do with the boost controller issues I've been having as well...
Team-Integra member (TheAlpha) Silver Integra LS-T 250whp/246wtq @13psi
Same issue here. Is there something going on with the EBC? A friend of mine has been having problems with it as of late.
sIrK
Post by sIrK »
I just installing the ebc with this ectune versión, may be the cause that i cant configure well?
TheGuardian
Almighty-Si wrote:Same issue here. Is there something going on with the EBC? A friend of mine has been having problems with it as of late.
Yea, ive had a lot of issues lately, even my Hi/Li boost switch stopped working, and I can't get my EBC to actuate either. I started a thread explaining my problems with the EBC: http://forum.ectune.com/viewtopic.php?t=2528
sIrK
Post by sIrK »
So, i must wait for the fix to begin to configure mi ebc, because i started to install all, the solenoid, wiring... this week with this version, not installed yet with last version.
TheGuardian
Kinda surprised Calvin hasn't showed up yet, im sure we'll be seeing him soon on this issue, it seems pretty wide spread.
TheGuardian wrote:Kinda surprised Calvin hasn't showed up yet, im sure we'll be seeing him soon on this issue, it seems pretty wide spread.
I just emailed Calvin, he says he will take a look at these posts tomorrow to see what could be happening, rest easy tonight!
i'll remove that now... it was during testing
civic4g
Post by civic4g »
So can we \"force update\" or only will be corrected in R12?
