F20B anyone?!?!?!?
F20B anyone?!?!?!?
I am looking for a base map for a f20b. i am wanting a stock map, no big upgrades. please help if you can. Wes
You should think so, but I'm not able to get the engine running at all with a modified h22 map. But when I use the original ecu from the f20b3 sohc engine I had it starts but runs as a bag of crap. I'm just not able to get it running with the chiped ecu. I'm gonna try more tomorrow. Maybe I'm gonna use a different ecu. So I was hoping somebody had a f20b oem basemap I could use.
[x]'93 Honda Civic EG9 VTi '93 Civic EG8 w/b16a2 swap '91 Acura Integra DA9project '95 Honda Accord Wagon w/f20b swap '89 Honda Prelude 4ws project car
the stock ecu is from a old f20b3 sohc engine. I just used it to check that the engine would actually start. I'm gonna test some more tonight with the chipped ecu.
After I had tried everything I could think of I mounted the chip that came with my ecu (po6) when I bought it and tried that instead of the demon. And the engine started at once... What have I done wrong when I made the h22 basemap!? And what is the stock map that comes with the demon because I can remember that I managed to start the engine with that. But I overwrote the code before I saved it
I'm using the basemap from a h22 with 290cc prelude injectors, the same size as the f20b dohc uses. Here is the .cal file which I'm using now, can anybody see if there is a setting or something I have forgotten to enable? Info about the engine: -f20b dohc vtec engine (stock engine w headers) -obd2 harness was scrapped since the ecu was from an AT car and the intake was smaler than the stock f20b3 we had. -290cc stock f20b injectors -po6 chipped ecu, vtec enabled. starts(at the first crank) and runs the engine with the chip that came with it (full throttle chip??)
- f20b_h22w290ccbasemap.cal
- (8.19 KiB) Downloaded 256 times
I'm still having problems with the f20b engine, the engine starts at once, but the headers turn orange after just a minute or so just idling. What is wrong, the af is ok could it just be the thin walls in the header?
